It is currently Thu Aug 21, 2025 9:19 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page 1, 2, 3  Next
 Post subject: Zero Fret or Not?
PostPosted: Sun Jul 21, 2013 11:03 pm
Last Name: Russell
State: Michigan USA
Greetings,
I am sorry if this has been asked before, I tried searching for "Zero Fret" but the only results I got back were for "Fret" and you can imagine how many irrelevant results that brought up.
I recently bought a LMI Parlor kit which will be my first build. I custom ordered it with a Gibson style dovetail neck and a 24.9" fretboard. I had the fretboard slotted by LMI since I wanted to minimize problems since I have never cut a new fretboard before. I have a lot of experience with guitar repair but as you know that doesn't necessarily make me an expert at building. [uncle]
My problem...
1. The fretboard is slotted for a Zero Fret but I prefer not to have one. I am most familiar with setting up a guitar with just a nut and no Zero Fret so I don't know the pro's and con's of having one. Can someone enlighten me on it?
2. If I decide to cut the Zero Slot off then I am going to have to shave down the headstock to bring the headstock veneer down to keep my 14th fret over the gap in the dovetail. What is the best way to plane down the headstock?
Any help of advice would be most welcome.
Bob
 Post subject: Re: Zero Fret or Not?
PostPosted: Sun Jul 21, 2013 11:15 pm
City: winnipeg
State: manitoba
Country: canada
Bob:
I prefer a zero fret on my ukuleles, less trouble.
Watch out for the nut-to-first fret distance when you cut it down. You are removing wood on both sides of the zero position. It is a detail but can alter the first fret tone.
Bob :ugeek:
PostPosted: Mon Jul 22, 2013 12:29 am
Last Name: Russell
State: Michigan USA
I think I have the concept down that the nut will need to be in the same place where the zero fret would be but that would mean I would have to put the nut on the plane of the fretboard but the headstock angle would be about 1/4" above that. The headstock veneer would not be able to come down to the nut because of the angle.
After my measurement it appears I have to plane the face of the headstock the same thickness as the headstock veneer which would then put the angle right at the nut.
If I didn't make myself clear I can post a picture of what I have (if that would help).
But my question was actually 1. what are the pro's and con's of having the Zero Fret. And 2 what is the best way to plane the face of the headstock if I decide to cut the Zero Fret off.
I have heard of guys using a round planer that attaches to your drill press (I forget the name of the tool) but I think they quit making them. So I need an alternate way of doing it.
OK, Here is a picture of what I am talking about. Notice how the nut will be well onto the fretboard? You will notice I have marked the fret position on the side of the neck? That is where the 14th fret is in the correct position and the 15th fret is directly over the gap for the dovetail.
Maybe I am missing something when I talk about planing the headstock down. Could it be I have the wrong neck?
PostPosted: Mon Jul 22, 2013 12:47 am
First name: Mark
Last Name: Sorrentino
You can't move the fretboard a little north? That would fix your problem.
The reason for zero frets is to make setup faster/easier although I've never done it. Makes sense though. Some people swear it produces open notes that sound more consistent with fretted notes but honestly that isn't an issue unless you're using pine as a nut material.
PostPosted: Mon Jul 22, 2013 4:17 am
First name: Tom
Last Name: West
State: Nova Scotia
What is the scale length of the fret board and what is the intended scale for the guitar? At what fret will the neck meet the body?
Tom
PostPosted: Mon Jul 22, 2013 5:50 am
I have never used a zerofret but I have noticed that a capo produces open string sounds more consistent with fretted notes. Bone always seems to dampen the open notes somewhat. At least that's my impression.
Sent from my GT-P3113 using Tapatalk 4 Beta
Under Compensated Nut!
PostPosted: Mon Jul 22, 2013 8:21 am
First name: Tony
Last Name: C
City: Brooklyn
Something seems wrong with that neck and fretboard. Lets assume you were going to use a zero fret, you would still need a nut to maintain string spacing. The amount of room on the end of the neck seems WAY big to me. If the sample nut you are holding up in the pic is .25" wide, it wont fill the space on the end of the fret board between the end of the FB and where the angle starts on the head stock.
I'm not trying to insult you or your ability to count, but are you sure you counted the frets correctly? I have never built the LMII parlor kit, but I don't think Gibson used a zero fret.
If the nut is supposed to sit on the angled face of the head stock, and you miscounted the fret board by one fret, and you have the body join at the 13th and not the 14th, all you need to do is move the fret board up so it ends at the angle of the peg head. All of your troubles would be solved. That's what it looks like to me.
http://www.CostaGuitars.com
PMoMC
PostPosted: Mon Jul 22, 2013 9:08 am
I don't think you can get away with shaving off too much of that head stock, a bit maybe and use thicker overlays. That and joining at the 14th and 1/8in fret might work out. You also could add a wedge of the same material of your overlay to fill in the triangle created by the overhang the overlay makes as it ramps up to the nut, that would be easy to do.
As for zero frets, they have unfortunately been associated with cheap guitars. I've always avoided them till I built my first Selmer guitar last year. In keeping with the tradition I used a zero fret and I rather like it.
PostPosted: Mon Jul 22, 2013 9:31 am
It looks like you were sent a 25.4" scale neck. Try measuring the neck to see if the distance is for a 25.4" neck. From the nut to the 14th fret is 14.08" for a 25.4" neck. For a 24.9" it is 13.8". You might need to add .25" if the kit is expecting you to put the nut on the fretboard side of the head stock angle.
PostPosted: Mon Jul 22, 2013 9:51 am
First name: Jeffrey
Last Name: Wills
City: Fairfax
State: VT
Zip/Postal Code: 05454
My suspicion is that zero frets were done in factories because they were a bit easier to crank out (nuts are way easier/faster to cut when they just guide the string from side to side) and reasons for their superiority were thought of after the fact. I can't really back that up - I just say that because historically they all seemed to exist at about the same time.
It is possible that it helps reduce the end tension that makes the early frets go sharp and clean up intonation, especially for open chords. But, compensating does the same thing. Most compensated systems basically just move the nut closer to the first fret by .020" or .030" - some systems go beyond that, but that is the basic starting point for most of them.
I'm not a fan because I could never get the tuning stability right - you have two fulcrums at the head instead of one, so is poses similar problems as having string trees on Fenders. Maybe there is a trick to it that I haven't figured out yet.
Tonally, I guess it is subjective. The open notes will sound more like fretted notes, but whether that is a good thing or not is where the subjectivity comes in. Sometimes on a bass it is frustrating when an open string rings much louder than a fretted string, so I can see some bass players preferring it, but most guitar players use that phenomenon to their advantage and would miss it.
PostPosted: Mon Jul 22, 2013 9:55 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Tony might have the answer here, and that is not an indictment of your counting ability. I use a zero fret and miscount all the time during layout. There is just so much temptation to start counting slots at 1 instead of zero. I like to count the slots "zero, one, two. . ." then mark the body joint slot so I don't forget the next time.
Bryan Bear PMoMC
PostPosted: Mon Jul 22, 2013 11:33 am
Last Name: Russell
State: Michigan USA
Thank you all for the advice and input. It surprised me a bit when I saw there were so many of you that want to help here. I tried asking the same question on another building forum but I left when I got yelled at by the moderator for putting a space between paragraphs... and scolded about advertising products that were not their sponsors... So I very much appreciate the friendly atmosphere of this place.
About the nut, If you look at the picture I posted I have it shown as if I were going to remove the Zero fret. If I place the nut on the neck as if I were going to leave the Zero Fret then the nut fills that gap between the fretboard and the angle line of the headstock. So it may be just the camera angle that makes it appear the nut is too thin.
I did count the slots correctly starting at Zero, One, Two.... The 14th fret is exactly at the end of the fretboard where the body meets.
The measurement I get on the fretboard (From the Zero Fret) is 13.8" which is the correct measurement for 24.9 scale
I am a bit confused with the neck.
If I place the nut on the fretboard side right where the angle of the headstock starts I get a measurement of 14" to the 14th fret.
If I measure from where the zero fret is (as in the picture) I get 13.8"
So it works out perfectly for a 24.9 scale on the neck and fretboard if I keep the Zero Fret. If I remove the Zero Fret then I either have a very large gap between the nut and the angle of the headstock. If I move the fretboard up then my 14th fret will not sit at the edge of the body (with will mean the 15th fret does not sit over the gap in the dovetail joint (problem for a later neck reset or removal)
That is why I was asking about planing the headstock down.
Currently the headstock is 1/2" thick. My headstock veneer is 1/4"
If I were to plane 1/4" off the top of my headstock that will move the angle down to meet the point where the nut sits (without the Zero Fret)
I hope that is clear.. I think I am starting to confuse myself... [headinwall]
PostPosted: Mon Jul 22, 2013 11:51 am
First name: Tony
Last Name: C
City: Brooklyn
Filippo Morelli wrote:
And if any of that information is off, Tony offers 110% money back guarantee on any thread where he posts, so you are covered! :mrgreen:
Filippo
I'm out of ideas. I'm cancelling that money back policy. It is costing me too much money. Especially in all of the "what wood is this" threads.
PMoMC
PostPosted: Mon Jul 22, 2013 1:33 pm
Sounds to me like you got the wrong neck. "If I place the nut on the fretboard side right where the angle of the headstock starts I get a measurement of 14" to the 14th fret." That measurement should be about 13 3/4", to match your FB scale from zero/nut to 14th fret.
"So it works out perfectly for a 24.9 scale on the neck and fretboard if I keep the Zero Fret." I think that's just a coincidence. You shouldn't have gotten a neck made for a zero fret unless you specified that.
I would not plane down the headstock. Just exchange the neck for the correct one.
1/4" is extraordinarily thick for a headstock veneer. Normally they are 1/16" or less.
Personally, I don't like zero frets.
Todd Rose
Ithaca, NY
PostPosted: Mon Jul 22, 2013 2:53 pm
Last Name: Russell
State: Michigan USA
I had an idea that it was wrong but wasn't exactly sure so I really appreciate all your help in sorting this out.
At least now I can call them and have a better idea of what I am talking about.
Thank you all for the help.
Bob
PostPosted: Mon Jul 22, 2013 4:22 pm
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
RusRob wrote:
Greetings,
My problem...
Bob
I've purchased serviced FBs from LMI and they always have some excess above what will be the nut (what I believe you are calling the zero fret). Have just cut the board at that first "fret" slot and touched to exactly the soundhole side of that slot so it's clean and 90 degrees to fit the nut above it. Thus the real fret #1 is the second fret slot on the serviced blank. Hope that makes sense.
PostPosted: Mon Jul 22, 2013 4:38 pm
I just checked LMI site and they don't sell a dovetail neck for the 24.9 scale length. They have bolt on necks in 12 fret slot head and 14 fret paddle for that scale length. I'm not sure which plan comes with the parlor kit but would imagine it is a 12 fret join. Check your plan, check your abilities, order the appropriate neck. If you need a neck that LMI doesn't supply, look up Hanalei Moon.
PostPosted: Mon Jul 22, 2013 4:55 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
It may be the wrong neck, but it will certainly work.
Use a zero fret, it's a good idea.
Put the fretboard right where you have it, with the nut right up against it. I always have the nut sitting on the fretboard plane, not the face of the headstock.
Install the headstock veneer so that it butts up to the back of the nut, creating a nut slot.
PostPosted: Mon Jul 22, 2013 5:38 pm
Last Name: Russell
State: Michigan USA
I just called LMI and it appears I did order the wrong neck.
StevenWheeler hit it right on the head. The Dovetail neck only comes in the 25.4" scale.
I ordered that neck because I am very familiar with with setting a dovetail neck and I just figured I would get the correct scale neck.
I could have made it work as Rodger Knox suggested but I prefer not to have a Zero Fret. Again I am comfortable with setting up a guitar with a nut. It just seems if you have a Zero Fret you loose a lot of adjustment when doing a setup.
LMI was great about returning this one and replacing it with the correct one. Unfortunately I can't get a dovetail joint on the new one so the headblock has to be sent back as well.
I am glad I decided to start with the neck and not the body.
PostPosted: Tue Jul 23, 2013 8:45 am
First name: Beth
Last Name: Mayer
City: Tucson
State: AZ
I'm pretty sure he has the wrong neck from LMI.
Filippo
Just read the OPs second post again...yup, wrong neck
PostPosted: Tue Jul 23, 2013 9:29 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I suppose the point is moot now, but I agree with Filppo that this was not a good situation for a zero fret. I like to keep the zero fret as close to the nut as possible. People who aren't used to a zero fret see it out of the corner of their eye and can trick themselves into seeing it as fret 1, suddenly a G chord is fingered as some kind of awful sounding F# frankenchord.
Bryan Bear PMoMC
PostPosted: Tue Jul 23, 2013 9:51 am
First name: Tony
Last Name: C
City: Brooklyn
I shall claim full credit for finding the solution to this problem in my unauthorized autobiography. :D
PMoMC
PostPosted: Tue Jul 23, 2013 10:14 am
First name: Mark
Good job Tony. Thanks for the help.
PostPosted: Tue Jul 23, 2013 10:52 am
First name: Tony
Last Name: C
City: Brooklyn
It was nothing. I knew right away when I looked at the pic that something was wrong and that the fit should be more gooder.
What would we do without you? idunno
Filippo
Probably not laugh as much....unless a few people, including yourself, step it up to fill the void. Shouldn't be too hard. I'm not that funny usually.
PMoMC
PostPosted: Tue Jul 23, 2013 11:29 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I think you're funny. . .
. . . Looking.
Bryan Bear PMoMC
Users browsing this forum: guitarjtb and 40 guests
